Tilt wheel control lever
How does the tilt wheel lever come out of steering column?
좋은 질문입니까?
John, Older models were threaded into tilt linkage, so to remove them you would turn counter clockwise to remove lever. If like the F150 with plastic tilt lever, lever is just a push/wedge fit on a tapered rectangle, remove screws under the steering column to remove trim and slide lever off taper shaft.
Check the attached link,instruction and guide, Good luck.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 10
지난 30일: 25
전체 시간: 5,717
