주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Microphone and earphone don`t work
Hello guys!
I have big problem with my Iphone 6. When I try to call someone I can`t hear any signal or voice. The person can`t hear me too.
I tried to record something with Voice Recorder - nothing. I tried to make a video with the camera, but there is no sound. On calls I can only hear in loudspeaker mode, but nobody hears me. I tested with bluetooth watch and I can speak, but only in bluetooth.
I am with ios10, but made hard reset and downgraded to ios9.3.5, but no result.
Do you have ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
It´s not a software porblem. Sounds like defective cirrus logic (audi ic) on the back of the logic board. It´s very hard to fix. You need to replace a bga chip.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Hi Marius, stumbled on this post with similar symptoms and wondering if you could clarify. I have an iPhone 6 and noticed similar problems after dropping it once. I cannot hear or speak during calls unless I use speakerphone or bluetooth headphones. I cannot record audio from microphones using video from front or back, nor can I record audio using voice memo app. Bluetooth and wired headphones appear to work, is that consistent with damage to the cirrus logic board being damaged?
I would find it unlikely that all microphones were damaged as well as the earpiece speaker, so the only other possibility I could conceive would be damage to a flex cables.
댓글 달기
Any water damage to the phone?
I like to start simple: change the earpiece speaker, front camera flex and Lightning port. That will replace both microphones and your earpiece speaker. Your loudspeaker is working, so you don't need to replace those.
There is a good chance the phone had some minor water damage and those components were damaged since they are the ones that have openings that water can get into.
iPhone 6 Front Camera and Sensor Cable
iPhone 6 Lightning Connector and Headphone Jack
iPhone 6 전면 카메라 및 센서 케이블 교체
iPhone 6 Lightning Connector Assembly Replacement
iPhone 6 Lightning Connector and Headphone Jack 이미지
상품
$19.99
iPhone 6 Front Camera and Sensor Cable 이미지
상품
$19.99
iPhone 6 Lightning Connector Assembly 이미지
안내서
난이도:
어려움
1 - 2 hours
iPhone 6 전면 카메라 및 센서 케이블 이미지
안내서
난이도:
운영
30 minutes - 1 hour
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
No water damages.
Everything started when I spoke with a friend in Facebook Messenger. It was OK 20 minutes and all at once he told me: I can`t hear you. I tried to recall but again no microphone. Then I noticed the problem with the earphone too...I bought the phone refurbished and since last week is mine.
댓글 달기
The audio jack is not working too...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The audio jack is part of the same flex that holds the lower microphone. If you replace the parts Josh mentioned, that will include the audio jack.
댓글 달기
귀하의 답변을 추가하세요
Nicky 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 122
