주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 6월에 출시되었으며, 모델 번호 B051로 식별할 수 있습니다.
I have a serious Problem
Hello I would like to know if there is a way to fix this but my beats solo² s460 stop working when it was playing audio and the device I was using to play it disconnected and the beats froze as soon as it disconnected it was stuck on a blue light and I held down the power button for approximately 10 secs but It was frozen
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
I've fixed it the buttons were shifted when I turned them on so the power knob wasn't touching the button to turn it off
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
Hi Adain, I would give them a hardreset, If this doesn't work it's an indication that the issue may be hardware related and will need a technician to check soldering, plugs etc.
Press and hold the power button for 10 seconds.
Release the button.
The battery Fuel Gauge LEDs will all blink white, then the first will blink red—this sequence will happen three times.
When the lights stop flashing, the reset is complete.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Didn't work thanks though
의
You could attempt to remove the battery and reset it that way.
의
댓글 달기
답변을 추가하세요
Adain Asir 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 671
