주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Can I use iPhone 5s charger port in an iPhone se?
So my iphone se stopped charging by itself today morning so i had it open to check the plug but it seems to fine now i have my old iphone 5s so is it possible to use the 5s charger port and switch it to SE?
thanks any help will be appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 달기
답변 4개
선택된 답변
No
20charbecausesomestupidpeoplesaidso
해당 답변은 도움이 되었습니까?
점수 5
댓글 2개:
just curious what is the difference?
bcux it looks the same to me online. i dont want to open up my 5s(which is never been opened).
Different connectors
댓글 달기
No, it seems it doesnt! The connectors types are reversed comparing to 5s, and they are part from the cable band which I dont imagine how’d be “easily transfered”. I lost some hours and money because of that comment!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Yeah, your right I tried swapping the port from a broken 5s I had laying around trying to fix my little sisters SE and it was a waste of time because it's exactly what you described.
댓글 달기
Actually, the charging ports are exactly the same apart from the socket where the home button connects to. The only difference is that it appears to have an extra bit of "housing" where the home button flex connection sits which can easily be transferred from the original cable anyway. I've just connected a 5S charging port to a SE and it charges perfectly!
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Can you use the home button and touch id Still cause I have an extra 5s part and I don’t want to buy something if I don’t have to
This is not true, the connector that goes on the logic board is different.
You are incorrect i wasted my time trying
댓글 달기
Well it worked perfectly for me so you must be doing something wrong or used too much pressure connecting it to the board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I’m gonna try out this project to see if I can get my Touch ID working on my old se using an iCloud locked 5s, I’ll let you know if it works or doesn’t work. And if it doesn’t then i guess I’ll have to resort to using the SE and a squared off iPod touch if I have to.
댓글 달기
귀하의 답변을 추가하세요
Poojan Joshi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 30
전체 시간: 17,393
