주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BMW 7 Series 4세대 플랫폼(E65, E66, E67, E68)에 대한 수리 안내서 및 정보입니다.
Windshield wiper arm not attached
How do I reattach the wiper blade arm on drivers side ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@troubleincali , Your BMW's wiper arm should be held on by a retaining nut, usually found under the plastic wiper arm trim cover. Your arm may be broken at the hinge in this case you will have to get a replacement. If it did indeed come loose and fell off you will have to find a correct nut to replace the one that has fallen off. If it is just a loose arm, remove the wiper arms trim cover, properly position the arm on windshield and retighten the nut snugly, put trim cover back in place. You may have to get the nut if lost from the dealer to ensure you get proper size and locking knurls on base of nut. You can also compare how it should be installed by comparing it to the arm on the other side. Check the attached video link,instruction and guide to basic wiper arm removal/replacement, Good luck.
https://www.youtube.com/watch?v=dQnhMn5V...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Ticia 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 2,074
