Change Battery Microsoft Surface 2
How do I replace the Microsoft Surface 2 battery?
What material should I use to assemble the screen with the back cover?
좋은 질문입니까?
좋은 질문입니까?
@piero90, Piero, remove the old glue/tape with a (little) heat and a plastic scrapper/credit card/fingernail, then use some 90% isopropyl alcohol and a lint-free cloth to clean the remaining adhesive. Use a good quality thin 2 sided tape to put back together, which you can find doing a google search/hobby shop/small electronics repair store when you figure which width would work for you. Links below show tear down of the Surface 2 and adhesive strips being applied. Check the attached links,instruction and guides, Good luck.
이 답변이 도움이 되었나요?
How I remove the ribbon cable in the Microsoft Surface 2?
@piero90 , Piero, at 27.00 min's in on video shows ribbon cable removal and the 2nd link here shows more detail of the cables removal, good luck with your device.
Then I have change the battery, I must to use glue or thermal past to reassemble the tablet?
@piero90 , Piero, it would probably be best to reapply the thermal paste if removed and glue to a like factory install to prevent possible problems. Have a good day.
So I must to use the glue and the thermal paste together?
지난 24시간: 0
지난 7일: 13
지난 30일: 32
전체 시간: 4,699
댓글 3개
I must disconnect the display from the rear panel with a heat gun, then to reassembly the Surface, I will have to use glue to assemble the tablet?
Piero Sabino 의
What should I use to connect the ribbon cable to the motherboard?
Piero Sabino 의
How do I remove the battery after removing the motherboard?
Piero Sabino 의
