주요 콘텐츠로 건너뛰기
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
70 질문 전체 보기
lcd turns off but laptop is on
my laptop has no battry and works with charger cable.
its screen turning off after afew minutes and in os i can turn it on with fn+f8 but after first screen off it happens after per min.
its wierd becuase i connected a monitor to my lap but it work and never shutdown but laptops screen gone.
its happen in setup bios or every where you think.
laptops screen gone but monitor crt remain.
can you help me????
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
Hi, Not sure about why in BIOS but have you checked the screen power settings in Control panel > Power Options when connected to battery and power.. I know that you have no battery installed but select screen power option for battery to 'never turn off' to see if it stays on. just a thought
thankyou.i removed screen cable not data that little one and its became dim from dark or screen of and now i did that you said but in setting of high performance and its on till now.
i decrease brightness and any setting at never.
dim level on 40% normal is 30% and alot of change at setting.
thankyou for respond and attantion
댓글 달기
답변 1개
Most likely the connection between the monitor and mother board is old and dead or damaged in some way
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
hi.can you see my new post
댓글 달기
귀하의 답변을 추가하세요
Emin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 173
