주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년에 Sony에서 설계 및 제조한 디지털카메라입니다. Wi-Fi, GPS 및 메모리 카드 슬롯을 갖춘 1,820만 화소 카메라입니다.
Program Selection Wheel not working properly
Hi,
hope you can help: when I select a program it is often lost. For example: I set the wheel on P but on the screen the selection is - M. I have to move the wheel just a little bit to have the right program set again, but sometimes it's immediately lost again.
Maybe dust under the wheel? How can I clean it?
Thanks,
David
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Now the wheel works (even if ha become a little bit harder to roll), thanks!
Davide
David, Glad to here it is working, pretty sure it will start easing up with usage after the cleaning. have a good day.
댓글 달기
답변 1개
선택된 해법
@catchtherainbow , David, Sony Cyber Shot, remove the battery, squirt a (little) 90% Isopropyl Alcohol under selection wheel and blow out/dry with canned compressed air. Repeat a couple time and this should clean out the dust/dirt from under wheel.
If this does not correct the issue button internal stops are probably worn and button assy. may need replace to correct. I will post a tear down guide if you wish to dig a little deeper into your device.
Sony Cyber-shot DSC-HX20V 외장 케이스 교체
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
David 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 55
전체 시간: 1,718
