주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Phone and sound glitch when headphones are plugged into auxillary port
I recently had my iPhone screen replaced after cracking it significantly. The man who repaired it said he saw my some water damage inside, but my phone had been functioning fine so I didn't think it was a problem. This was about a month and a half ago. For the past few weeks, when I plug headphones into the auxiliary port, the volume will change on its own at random intervals, and sometimes the sound will cut in and out. I have tried turning the device on/off again, blowing in the port to remove any dirt/dust, and rotating the headphone jack, all to no avail. I have checked the pair of headphones with other devices and they are working perfectly so I have concluded that it must be the iPhone.
None of these issues occur when I play music from the iPhone out loud (without anything plugged in the auxiliary port) although the sound is a little gargled (my speakers are sub-par, also might be due to water damage or some other cause).
Does anyone know what might be causing these bizarre glitches? And are there any replacements/repairs possible or do I need a new device?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
I would first check for any liquid damage on the charging port dock connector on the logic board.
You can try cleaning the headphone jack with tweezers or something equivalent as there may be dust or lint stuck deep inside the headphone jack.
If there are no signs of liquid damage on that connector then the headphone jack is most likely damaged from liquid and the whole charging dock assembly would need to be replaced.
The charging dock consists of the main microphone used for calls, the headphone jack, connection to the loudspeaker and the main antenna to get cellular / service provider signal for the sim card / phone.
You can buy a replacement charging dock if you do choose to replace it yourself here:
iPhone 6 Lightning Connector and Headphone Jack
Guide to replace the part:
iPhone 6 Lightning Connector Assembly Replacement
iPhone 6 Lightning Connector and Headphone Jack 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
When I plug my headphones into my phone when I was doing a video call on zoom it freezes and restart.I want know what is the problem and how to fix it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
So I’m wearing Bluetooth headphone and I would usually charge my phone and listen to my Bluetooth headphone but this time I plugged my phone into one and every time I put it in the volume stops working and it won’t let me turn it up with the buttons or the screen
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Madison Burgess 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 44
전체 시간: 34,611
