주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion 14-b120dx 노트북은 2013년 10월에 출시되었습니다. 이후 HP Pavilion 15‑au010wm 모델로 대체되었으며, 이 모델은 현재까지도 판매되고 있습니다.
Why doesn't my computer have sound?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
A couple of things could lead to this. First, check to see if you have muted the computer. If this is not the case, then check to see that you have no external sound devices hooked up to the computer. If still nothing is found and no sound is playing, try to update the drivers for the sound card, or re-install/ find another comparable sound driver. If still nothing has worked, than you need to try to replace the sound card.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi Erin,
FYI. Not too many laptops, if any, have separate 'sound cards'. The audio controller is built into the motherboard. If the problem is on the motherboard it is easier to buy a USB sound card adapter than to either try and fix the motherboard (hard) or replace it (expensive), if you want to have sound and keep the laptop.
의
댓글 달기
답변을 추가하세요
Robert K Boschert 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 12
전체 시간: 440
