주요 콘텐츠로 건너뛰기
The HP Compaq 2510p has a part number GM651AW and was released June 2007. It features an Intel Core 2 Duo ULV processor and 12.1 inch display.
4 질문 전체 보기
My laptop won't power on.
I press my power button, and my computer wont turn on. There's no lights when the battery is plugged in either. Does anyone know whats wrong?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
Student question
댓글 달기
답변 2개
선택된 답변
You can try doing a static discharge . Remove the battery and unplug the laptop so there is no power to it at all . Then hold the power button down for 60 seconds this drains any residual power from the memory and allows a clean boot. Then reconnect the battery and power and boot the computer normally. If this gives no Joy test your power adapter to see if there is an issue there .If the adapters not providing power it wont charge the battery Hope this helps
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Your battery may be defective. However try removing the battery for 60 seconds and see if the problem persists.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dan Champagne 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 2,352
