주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google과 Samsung이 공동 개발한 Nexus 제품군의 10인치 태블릿입니다.
optimizing apps at startup
When starting up it begins optimizing apps and never quite finishes. After repeating this several times over a few days, it now begins the same way but in a short time it blinks and then goes dark.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
I found a solution that need no flashing.My s6 edge plus behaved same way.I left like that because I did not want to lose some applications. On the third day it booted normal.
의 공유
댓글 달기
답변 4개
선택된 해법
This could be a memory glitch . Holding a bad boot in the memory and booting off the same boot cycle. open the tablet and disconnect the battery then reconnect and reassemble and reboot . This video will help you disassemble the tablet the battery removal is not necessary just disconnect the battery and reconnect .Hope this helps
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
If you have Zedge, this is what is causing it.
I had also done other updates and thought it was Android System WebView as it started right after that had updated. Then I read it's Zedge and I've had that program for almost 2 years. I had restarted phone and was again stuck on "Optimizing", but for me each time it has been a good 20 minutes.
I uninstalled Zedge and it started right up, no Optimizing. Thanks for everyone who figured this out!
이 답변이 도움이 되었나요?
점수 4
댓글 8개:
OMG thank you soooo much! It worked and I didn't lose my ring tones! I guess when I'm ready to change them I'll just reinstall then uninstall when I'm finished
의 공유
Yes, Zedge is the culprit, just uninstall, reboot and you are good to go.
의 공유
Worked! Thanks
의 공유
Genius once I uninstalled Zedge the optimizing 1 of 1 was gone this really worked thanks a bunch
의 공유
I uninstalled Zedge and the phone still goes into Android starting 1 of 1
의 공유
댓글 3개 더보기
댓글 달기
I disconnected the battery, then recharged completely. The nexus started back up like it should. However, the screen does not respond to touch. Yikes! I must have messed something up.
Any advice?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I know this is a long time ago,but…
Ensure that the ribbon cables you disconnected to replace the battery are fully and properly reinserted.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David Lovin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 43
전체 시간: 17,172
