주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Syma X5C는 카메라가 내장된 4채널 쿼드콥터입니다.
drone Won't take off!
When my Syma is all paired up to to the controller and its ready to fly it won't take off. I've had a look and realized that the rotors are reversed and push the quad copter down. i have tried everything i know of such as calibrating the drone. i have no clue of how to continue , could someone please help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
There are 2 motors that turn clockwise and 2 that turn counterclockwise. The props are also different and each is marked to go on their matching motor. On each arm of your drone there is either an A or B and on the props 2 have an A and 2 have a B. Make sure that the props are on their proper motor.
I don't feel calibration is your issue but.....to recalibrate the gyro: After you bind your Tx and drone with the up/down throttle sequence(and have solid lights), move both Tx sticks to bottom right. The gyro will recalibrate after a second or 2 and the lights will flash then return to solid.
I hope this helps and you are flying again soon if not already.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
My drone won't fly ! Battery's are charged seem to be the connection from battery to drone! any suggestions ??
의
댓글 달기
One of my B wings will not move what should I do?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Billy Frank 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 19
전체 시간: 5,829
