주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년 후반 - 2011년 초반 출시, 모델 번호 NB505-N500BL
It won't turn on
I can't turn it on at all
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
선택된 해법
Hi,
Try the following,
Disconnect the charger (if connected), then remove the battery from the laptop.
Press and hold the power button on the laptop for about 15 seconds then release the button.
Reconnect and switch on the charger (leave the battery out at this stage).
Start the laptop by pressing the Power button.
If the laptop starts, allow it to boot all the way to the Windows desktop. Allow it to 'settle' for a few minutes.
Then shutdown the laptop in the normal manner.
When the laptop has fully shutdown, switch off the charger and disconnect it from the laptop.
Re insert the battery into the laptop, reconnect and switch on the charger, then switch on the laptop.
Allow the laptop to boot all the way to the Windows desktop.
When it has finished booting and the Windows desktop is displayed, check the charging state of the battery. If it is charging allow it to fully charge before switching off the charger and disconnecting it from the laptop
Here is a link to the Ifixit guide on how to remove the battery in your laptop.
Toshiba Mini NB505 배터리 교체
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
It worked for me; thank you, but what a palaver to go through each time.
의
Worked like a charm
의
댓글 달기
답변을 추가하세요
Adriana Real 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 4,216
