주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S5 NEO (SM-G903F)는 Full HD 해상도 5.1인치 Super AMOLED 화면을 장착하고 있습니다. 전면 카메라와 후면 카메라는 각각 5 megapixels과 16 megapixels로 작동합니다. 휴대폰 내부에는 64-bit Samsung Exynos 7580 프로세서, 16GB 내장 메모리, 2GB RAM 및 2,800mAh 배터리가 장착되어 있습니다. 치수는 142 x 72.5 x 8.1mm, 무게는 145그램 입니다. 최초 S5와 비교하여 Galaxy S5 Neo는 전면 카메라, FM 라디오 및 더 빠른 LTE (Cat6)와 같은 더 나은 기능을 제공합니다.
How do you get into this thing
AAAAAARRRRGHHHH
Someone help how the heck do you get into this thing?
this has turned into a nightmare I'm replacing the dock port on this I've already busted the screen (glass just came straight off the LCD but thats a whole different story)
I have also removed the 13 screws from the frame under then screen but i cannot get all the casing off the other side to get into where the motherboard & dock port is.
I have undone the clips on the inside of the battery recess but it all is stuck down tight i don't want to force it too much this repair has already cost me big time
Someone PLEASE help & point me in the right direction
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@inthebox ,Kenny, Link to partial tear down of the S5 Neo and a 2nd link which may have more info., Good luck.
Samsung Galaxy S5 Neo 디스플레이 교체
http://www.sonymobilephones.com/samsung-...
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Hi Thank you for that i did see that but it only goes as far as taking screen out not going in as far as getting motherboard out. Someone was kind enough to come & show me how. Its deceiving it looks like it should come away from the outer frame thats what i was looking at & couldn't figure it out it actually comes apart inside.
의
@inthebox ,Kenny, thanks for posting back, happy to here you had success with your device. Have a good day.
의
댓글 달기
답변을 추가하세요
Kenny Leonard 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 553
