주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Black & Decker 무선 18V 드릴 모델 PS1800. 330 인치-파운드의 토크와 32단계 클러치를 갖추고 있습니다. 2006년에 출시되었습니다.
Drill Bit Is Stuck
If the drill bit is stuck in the drill and you cannot remove it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
OMG. I tried everything and happen to come across your answer. Worked immediately. Thanks sooooooooo much.
의
댓글 달기
답변 2개
가장 유용한 답변
There’s a way to get the bit out that worked on an inherited Dewalt DC970, but it is sacrificial to the drill bit stuck in the chuck. This should work on your drill as well.
The bit WILL be sacrificed, so if you need it and can’t quickly replace it find a non-destructive solution. Most of the time you can get a new bit individually or in a bit set if the cost is just about the same. What I did to fix it is I locked the motor switch and got scrap wood and bent the bit to a 90 degree angle. That was sufficient to beat on the cuck and loosen it with brute force. It may damage some cheap chucks beyond repair, so keep that risk in mind. It didn’t happen on mine since the pre-20V DeWalts often use a Jacob’s chuck (not true on the newer 20V ones!), so YMWV based on who made the chuck.
It has always worked fine since but that may be in part due to the fact I put 3-in-1 oil in the chuck to help it post beating and sanded the rust inside as I can to prevent that from causing another problem. It also helped how smoothly the chuck moves as well, so it compensates for any potential damage. It’ll never be perfect again because of the obvious internal issues and beating I did, but I intend to use it until the batteries are dead. As far as batteries go, it isn’t worth buying any because I can only choose 3rd party NiMh or 1st/3rd party NiCd. Every time I’ve used NiCd packs, they’ve been nothing but terrible. Unless I get another plastic chuck DeWalt (and in the future one with a metal chuck) for batteries and the DCA1820, the thing is a total loss.
If you can afford it, find a drill with a metal chuck. You’ll thank yourself when it’s still holding up better than plastic.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
'Drill bit Is too tight
If the chuck is not releasing the bit and it is really tight try using WD40 to loosen it and extract the drill bit.
Not using the drill correctly
If the drill bit is still not coming out hold the chuck and run the drill in reverse
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Hamza Nawaz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 25
전체 시간: 14,803
