주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Marantz 홈시어터 AV 리시버 및 구형 오디오 전용 리시버에 대한 지원 및 수리 정보입니다.
Why won't my amp turn on?
I have a Marantz model 1040 amplifier that wont turn on. I checked all of the fuses, they are good, and when the amp is plugged in, I can get power through one of the outlets that is on the back of the amp. Still doesn't turn on. Not sure where to start.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
kalewenczel I'd start by looking at the power supply for the amp. You will have to disassemble it. Take plenty of pictures and post those with your question. Use this guide for that. It will allow us to see what you see. Check the large capacitors and diodes on the power board. Attached image shows the location of the parts
이미지
and here is the schematic for it
이미지
You do not just want to check the fuses for continuity but check to see if you have power on them as well. Let us know what you find.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Check the power switch on the receiver. Make sure is is getting power to it and not broken inside. This units are notorious for this.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kalewenczel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 22
전체 시간: 8,854
