does not poke coffe pod
can I get my Kurig coffee maker repaired........it doesn't poke the pod for the water to go through the pod......... feels like it might be bent ???
좋은 질문 입니까?
좋은 질문 입니까?
@esmills__16 if it is truly bend you can replace the needle assembly (depending on your model). Every now and then you can find the parts at places like this. On this guide in step 9 you see two small Philips head screws on the left hand side (above and below the water inlet). Those hold the needle assembly to the top part. Remove those to remove the assembly. Again, take lots of pictures and post those with your question by using this guide.
안내서
난이도:
아주 쉬움
2 - 5 minutes
안내서
난이도:
운영
30 minutes - 1 hour
해당 답변은 도움이 되었습니까?
My experience is some pods have a harder plastic type covering rather than a thinner foil type.
It looks like the bottom needle that punctures the bottom of the coffee pods has come out of the assemble. Can I put it back in or do I need to get a whole assemble replacement?
해당 답변은 도움이 되었습니까?
I took the bottom assembly out, but I didn't see a needle. It no longer makes a hole at the bottom. What can I do?
해당 답변은 도움이 되었습니까?
24 시간 전: 12
7일 전: 59
30일 전: 247
전체 시간: 27,250
댓글 7개
@esmills__16 can you post some images of the puncture needle? Use this guide 기존 질문에 이미지 추가하기 for that. What exact model is your Keurig?
oldturkey03 의
no photos but he took it apart and back together again....and it is working.....thank you so much for your help........Ellen.
Ellen Sergas 의
I am new to this site, but i am trying to figure out why the exit puncture needle is not poking a hole through the bottom of my coffee pod that i put in?
tammymartin16 의
I am having the same problem!
Jolene 의
I'm having the same problem. So I improvised and punctured a whole at the bottom and it works.
Ericka Barrett 의
댓글 2개 더보기
