주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Epson Artisan 837은 2011년부터 Epson에서 생산한 올인원 프린터, 복사기, 스캐너 및 팩스 기기입니다. 모델 번호는 C11CB20201입니다.
will not print black ink
my printer will not print in black I have tried a new cartridge and still wont print. Any ideas....
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 10개
My printer black ink was so clogged no black was printing at all. Reason was printer sat for 7 months without use. colors worked but black did not. Cleaning print head several times but still no black. .I thought as a last resort before buying a new printer i would try something else. I put the printer in change cartridge mode, removed the new black cartage, put a soda straw over the cartridge nozzle in the printer, took the head of the pressure tank hose and blew about a hundred pounds pressure through the straw and print nozzle , I could tell when the nozzle cleared, It now prints black ink.
Hey, This is very common issues of Epson printer not printing black, but you do not worry, Here is the best procedure: http://www.printersupportplus.com/why-is... and you can quickly fix your problem.
Does anyone have a software hack to make Epson Artisan 837 print only black and white? That is, without using colours under the black. I have only printed black and white, and don’t want to keep buying the colours. I only want fax capability.
This is really common issue in Epson Printers, I was facing same and I got the solution on Internet https://tinyurl.com/y52t4tmd Follow the steps to get rid of this issue
Looking for canon printer wireless setup on Mac iOS have any technical term error can visit my web https://bit.ly/3iEeTo2
댓글 5개 더보기
댓글 달기
답변 8개
선택된 해법
@malyo1 , leonard, you may want to try cleaning the print head. Below is a informative link on trouble shooting the issue and a few different ways to clean print head. Good luck.
http://www.inkmagic.com/shopcontent.asp?...
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
I have done that; nmerous times NG
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
For those who are still having the same Epson printer issue.
Quick question. Are you sure it's a printer fault?
Well, there are a couple of reason your printer is not printing black like
1. It is printing in rich black.
2. Issue in the printer head
3. Outdated driver
4. paper related issue
Well, you can run the cycle clean either from the printer panel or from the computer. It works sometimes. If it doesn't fix your issue, you can follow a detailed guideline which I found in this article https://www.workaroundtc.com/why-is-my-e...
Or you can also watch this video for your printer solution https://www.youtube.com/watch?v=JkGBsxME...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This is a really common issue in Epson Printers, I was facing the same and I got the solution on Internet https://bit.ly/3reW0Nh Follow the steps to get rid of this issue
이 답변이 도움이 되었나요?
점수 0
댓글 달기
These troubleshooting steps are for Windows 10 users who are facing problems with the HP printer that is printing blank pages.
  • Turn Off your HP Printer by unplugging the power cable from the back of it.
  • Uninstall the HP Printer drivers from the Control Panel of the computer.
  • Delete the HP Printer from the Devices and Printers list.
  • Turn On the HP Printer.
  • Reset the Wireless Connection by holding the Wireless Button on the printer.
  • To make sure Wireless Connection is Reset (Wireless Light will start blinking)
  • Resetting the Wireless connection will update your Printer Firmware.
  • Now Connect your HP Printer to the home network again.
  • Open HP Smart App on Windows 10 computer.
  • Click on Setup a new Printer.
  • Follow the instruction on the HP Smart to set up the HP Printer.
  • Once it’s completed, the computer will be updated with the latest HP drivers.
  • Now print any document from the computer and it will start printing in color and black.
  • Printing blank pages problem in HP Printer will be fixed completely after this troubleshooting.
If you need more help related to this problem please give a visit to our blog ” HP Printer Printing Blank pages
이 답변이 도움이 되었나요?
점수 0
댓글 달기
A printer going offline regularly happens because of varying conditions, particularly the WIFI, connectivity, and power supply issues. Brother printer offline is no exception as it also has its share of issues like brother printer shows offline windows 10. Printers are sensitive devices that easily react and send a ‘printer offline’ message even when there is only a little deviation in the power supply.
Visit us at https://askanyquery.com/tech/what-to-do-...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Truvic Online Provides Printer Repair Services. Truvic deals with almost all the brands which are found in the market. Canon, HP, Epson, Brother, Panasonic, Xerox, Toshiba, Lexmark, Samsung, Kyocera, TVs, Oki, and the other brands the users might face any problems with. visit my Web https://truviconline.com/best-printer-re...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I used baking soda for my printer and diet coke to get her back on line. Be mindful to cover generously in and out of the unit. Be sure to do it in the dark no lights on. Wear a good pair of safety slippers with heels. Parting your hair in the middle is optional.
(Note). Add Diet Coke super fast after a super heavy dusting of baking soda. Dig your slippers heels in. And go get her.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
leonard cronan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 20,498
