주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Moto G4 Plus는 Motorola의 Moto G4를 개선한 모델입니다. Moto G4 Plus는 지문 센서, 향상된 메모리 용량, 업그레이드된 후면 카메라를 제공합니다. 모델 번호는 XT1642 및 XT1644입니다.
moto g4 plus Micro USB Replacement
Can you put up a video on how to replace the micro usb port on the moto g4 plus?
Mine had the plastic literally melt after connecting in to an apparently faulty car charger.
Much Thanks and keep up the great videos!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 4개
Your phone didn't warn you what was happening?
의
Hi, did you solved this problem? I need to replace my charging port too.
의
Nope, ended up sending it in on warranty and getting a new phone.
의
Hi
I purchased a rebuilt Moto G 1st generation smartphone but the charger port was broken after I paid for it , and before I received it.
Can you provide an instruction manual or video? I have seen one but the soldering alone I know is more than I can do myself. Can you help?
의
댓글 달기
답변 1개
가장 유용한 답변
william_oliveira87, John Linden, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a USB charge port attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=8jqw-KwC...
https://www.youtube.com/watch?v=Bl_6g4GV...
http://www.ebay.com/itm/2X-Dock-Connecto...
이 답변이 도움이 되었나요?
점수 7
댓글 달기
답변을 추가하세요
John Linden 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 18
전체 시간: 10,936
