주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 여름에 출시된 XPS 14 L421X는 3세대 Intel Core 프로세서, Nvidia 그래픽 카드, 1600x900 픽셀 해상도의 14인치 화면을 특징으로 합니다.
Screen blank, doesn't turn on
My Dell XPS 14 doesn't turn on after plugging faulty powerbank on it to charge. Is it the fuse? And if it is where is it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@chainsawfelix could be a fuse could be many other things. First thing you want to do is to install an external monitor and see if that displays. If so then it is possible that you have a damaged backlight circuitry (including a backlight fuse, failed LED driver etc.) as we as a bad LCD etc. In order to find out anything about fuses, you will have to find exactly what motherboard you have. Any number on it that might help to identify your board will be useful.
If an external monitor does not display anything you are having issues with the video circuitry that is unrelated to any fuse.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Felix Xu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 676
