주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Loud speaker not working
After catching my iPhone 6 on fire replacing the battery I decided to try and replace all the parts that weren't working correctly. Right after it caught on fire I cleaned it up, put in a new battery and it seemed to work fine. The loud speaker was a little tinny sounding and the headphone jack didn't work all the time. I then replaced the lightning port headphone jack with a used OEM part off of eBay and that solved that problem. The issue I am now having is that I removed the tinny sounding speaker and replaced it with several other loud speakers but none of them are working and I threw out the old one. I've tried restarting the phone and everything but no luck. I don't understand how it worked with the old one in but no sound at all from the replacement ones. Any ideas?
Update (12/05/2016)
Still not working after cleaning the contacts. The first lightning port connector and speaker I used was from ifixit and the speaker did not work. I then replaced the ifixit lightning port connector with an OEM one because my cell signal was really bad. That fixed my signal but not the speaker. I then ordered an OEM speaker and put it in and if I would go into settings and turn the volume down in sounds and then try one of the ring tones then I could hear the tone one time at a very low volume. Now that I've disassembled again and tried cleaning I hear no sound.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Small parts (like speakers) are notoriously for having high defect rates. That said, it seems odd that you could have so many bad speakers. Here are a few things to check:
  • Because all of this started happening after you replaced the Lightning port, check it to see if the speaker contact points (look at this image) are clean. Sometimes our body oils impeded a good contact.
  • Check your speakers to insure they have the pins shown on the right. This is on the "under" side of the speaker. If they are bent or flattened, your speaker will not work.
  • Otherwise, follow this guide to insure you did not forget anything.
iPhone 6 Speaker 이미지
안내서
iPhone 6 Speaker Replacement
난이도:
운영
20 minutes - 1 hour
iPhone 6 Lightning Connector Assembly 이미지
안내서
iPhone 6 Lightning Connector Assembly Replacement
난이도:
어려움
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
The fire may have damaged the logic board, even though things sorta worked at first (tinny sound).
댓글 달기
귀하의 답변을 추가하세요
Mark Metheny 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 255
