주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Big Wheel은 주로 플라스틱으로 제작된 삼륜차의 일종으로, 앞바퀴가 매우 크고 지면과 매우 낮게 위치한 것이 특징입니다.
Steering column is stiff
I recently put together a kids big wheel and the steering column is very stiff and will hardly turn. Obviously this isn't something that is adjustable given the set up, but I need simple solution so my three year can steer it. Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Try adjusting the height of the handlebars by loosing the screw in step #5 of this PDF and lifting slightly till it turns freely then tighten it back down:
originalbigwheelparts.com/images/bw_assy_instructions_pictoral.pdf
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Kristina Johnson, This may also help, take the column back apart and apply a little/ thin coating of Vaseline on column and reassemble. Good luck.
의 공유
Neither of the above helped a bit. Cannot be steered by a child.
의 공유
Item is a piece of junk.
의 공유
Agree, the Big Wheel has been unused for over a year. Every few months my kids and their friends get on it and just as quickly get off. I would greatly appreciate someone sharing a fix if there is one out there
의 공유
댓글 달기
To any parents who bought this for their kids for Christmas and are running into this problem - the solution is candle wax!
Simply apply a thin layer of wax to any surface that rubs in the steering assembly (underside of the handlebars, front fork spindle, inside the hole the spindle goes through, etc.).
I was a little skeptical given the apparently unsuccessful petroleum jelly suggestion, but gave it a shot anyway, as I've used candle wax to lubricate wood in the past.
Not sure how long the effects will last, but it works great so far!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kristina Johnson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 44
전체 시간: 2,319
