My camera wont focus
My camera is having trouble with auto focus. On auto I can hear it trying but the picture just get more blurred. On the smart settings I can get it to focus but it requires zooming in more than I would like.
좋은 질문입니까?
좋은 질문입니까?
see if motor focus len is work free and correctly, if it have a slack in gear, possibly have to change th lens.
이 답변이 도움이 되었나요?
Another thing you have to check is the linear resistor - ie the sensor that detects the focal length. If the ribbon is loose from its connector, it may not giving this information. So it is stuck at a specific focal length. You can check if this is it, if the you can see picture on the LCD before you rotate the lens to the normal shooting position. I mean, when the lens is in its OFF position.
In order to access the aformentioned connector you need to:
1) Remove the back cover
2) carefully remove the ribbon that is attached to the outer contacts by lifting up the lock mechanism on the back side of the connector (the opposite side of where the ribbon is inserted).
3) There are 2 connectors remaining, the smaller one is the one to check.
이 답변이 도움이 되었나요?
Hi! So if I can see an image even if the lens is in the "off" position, that would mean I have that "locked at a specific focal length" problem?
지난 24시간: 2
지난 7일: 10
지난 30일: 39
전체 시간: 1,631
