주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PS4 컨트롤러 모델 CUH-ZCT1. 소니 컴퓨터 엔터테인먼트에서 2013년 11월에 출시한 이 6축 3.7V 리튬 이온 배터리 컨트롤러 수리는 복잡하지 않습니다. (참고: 해체 안내서는 이 모델용이 아닙니다.)
The square button is not work
The square button when I press on button is not work what I do
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 2개
you can replace the square button. you can order the motherboard from the IFIXIT site. and you can see how to fix also on this site.
의 공유
Yo no lie all I just did was get some scissors and pull up tried to wedge it in the side and just keep doing that trying to take the square button out than just pull up Spotify and keep trying use square till it work I swear try it
의 공유
댓글 달기
답변 5개
선택된 해법
Hi Amjad!
You can find our repair guides here for fixing or replacing the buttons on this controller:
DualShock 4(CUH-ZCT1U) 버튼 교체
We also sell replacement parts for the controller if you need them. These are the buttons:
DualShock 4 Controller Action Button Covers
Includes the plastic action button covers and the button gasket 이미지
제품
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Make sure to clean the connection to from the conductive film to the motherboard.
https://youtu.be/Lx3La8a169Q
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Thanks on the bottom of the phones keyboard, the square button doesn't work. How do I get it back working?
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
How to make this work
의 공유
댓글 달기
I was having issues with my left analog stick constantly drifting. Took the controller apart and cleaned it. Now it works great……except the square button doesn't work now. I'm thinking it's the clear film. May have a tear but I can't tell. Hope that info helps someone. Still working on my square button. Thinking about buying another mother board.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I did same thing as Jason above, took controller apart cleaned it thoroughly put back together and square button not working.
의 공유
댓글 달기
Exact same thing happened to me cleaned joysticks sensors and now square button doesn’t respond, I can see and feel it makes contact but no response I was thinking it was the ribbon strip because a couple of connections on the ribbon were folded back from disconnecting and reconnecting so many times maybe this could be the issue?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Amjad Badkook 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 85
전체 시간: 88,488
