주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년 출시 - Core i3-2330M 프로세서
non stop shutdown turned on loop
my laptop goes on a turned on-shut down loop.first it went on on its own without me pressing the power button,then after 2-3 second it turned off on its own without me reaching the windows screen.can someone help me?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Sounds like you are boot cycling... this means there is a hardware problem, and is commonly a storage problem... I would say take out the HDD and see if the bios will load but I have have one of these all though be it a intel core i5 from old but this computer has the worst HDD placement ever... as in need to remove the motherboard from computer bad... and that may not even be the problem.... but try this first, reseat the ram (take out and reinstall) and see if it boots
댓글 달기
답변 1개
Looks like you have a gpu failure.
Sometimes helps if you take it appart and clean the cooling sistem , but in most cases the only solution is the gpu reflow / reball.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
fahri a 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 5
전체 시간: 326
