주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대 Samsung Gear, Samsung의 Tizen 스마트워치 OS를 실행하는 둥근 스마트워치 입니다. Gear S2는 2015년 10월에 출시되었습니다.
Bezel ring repair or replacement
My bezel ring fell off my watch. Can you fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 2개:
My bezel ring is very difficult to turn either direction it's very sticky , how can I take it off and clean it and put it back on
댓글 달기
답변 6개
I just found this a few days ago. I have ordered the parts. :)
https://www.youtube.com/watch?v=puASQxWC...
Much luck!
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
where did you order from?
You can find them on eBay and on Amazon, the Amazon ones are for the rolex submarines, but I would think that they can work, the link is https://m.aliexpress.com/amp/item/327710... . Keep in mind that you will have to find out the size of the watch face or bezel so that the insert will fit perfectly and so that it may not even need the use of glue. So I would suggest going to a jewelry store and seeing if they can inform you on the correct size insert to buy. And you can get it from multiple different sites, not Just the one I provided.
댓글 달기
You can Glue it on with gorilla glue or sticky silicon glue. The inner part of the bezel is called a bezel insert, I have looked all over the net for ways to repair it and have only found one video as listed by the poster above. But if you entirely lost your bezel insert on the street or anywhere and do not have one in possession, you can just get a bezel insert from a old watch or order one . After getting a new insert, you can just glue it on. Just be sure to find the right size, for example: if the bezel size is 44mm, buy a 44mm bezel insert. This will work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
looking for the parts. I lost the ring and all
이 답변이 도움이 되었나요?
점수 0
댓글 달기
https://rounded.com/gear-s3-frontier/
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Lost my bezel anyone know where to replace it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My bezel fell off my Gs2 watch how easy to get another and repair?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Frank Sutterby 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 22
전체 시간: 24,389
