주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Home button not working but Touch ID does
Hello,
I've got a weird issue after a screen replacement: my home button doesn't work even if Touch ID does. I tried to install a replacement home button but the problem wasn't solved (and obviously the replacement button did not support Touch ID). What could be the problem? I thought about the flex cable that connects the button to the motherboard but if that was the problem even Touch ID should not work.
Thank you!
Walter
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Logically, you would expect the Home button action to work if the Touch ID works. The usual question is normally the opposite situation.
In your case, there could still be damage on the extension flex that runs beneath the backlight shield. Just think of it as a highway with multiple lanes. If the Home button lanes are damaged but the others are not, then you would see similar symptoms. You should inspect it closely and test continuity on each pin to be certain.
The other possibility is in how you are re-assembling the home button, specifically the backplate (iPhone 6 Plus 홈 버튼 어셈블리 교체). this is what the "button" presses against. If it isn;t making solid contact, the the button press will not be noticed.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Well, I guess the problem was indeed the flex cable. Thank you for your answer and detailed explanation!
unplug the charging port and battery and it should fix the problem
댓글 달기
iPhone 6.
Touch ID works, home button doesn’t.
I changed the suspected part - flex cable. Problem not solved.
Now, I changed the home button, and found that new home button is working, but at the cost of Touch ID.
Have anyone incurred a similar problem before. If so, what is the solution.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
yes i have with the seven and the five s just unplug the battery and the charging port and it should work , i think the update is the issue
댓글 달기
귀하의 답변을 추가하세요
Walter Simoncini 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 9,267
