주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei의 2016년 플래그십 스마트폰입니다. 유니바디 케이스와 Leica와 협력하여 개발한 듀얼 후면 카메라 시스템이 특징입니다. 32/64 GB 저장 용량 옵션과 6가지 색상 마감으로 제공됩니다. 모델 번호는 EVA-L29, EVA-L19, EVA-L09입니다.
touch screen not working after screen replacement?
Hi everyone! i have a big problem. I've just replace the screen of my huawei p9 (it has been a VERY HARD work), when i've finished all, i connect all the cable, i turn on the phone, the screen work but the touch screen doesn't. What happen? how can it not work? i've done everything right...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
hi, have you solved? Did you understand what the problem is?
I have the same problem and I am very worried because the phone is not mine but my brother and he is convinced that the touch screen does not work because I have not been able to fix it. I do not want problems with him. Please reply
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Resurrecting something from the dead here but I’m seeing issues with a P9 myself. Touch is working but occasionaly unresponsive to swipes (especially left-to-right) or misinterprets swipes as touches.
Googling leads me to believe there’s a grounding problem or something. Or perhaps the part is just bad. I’ll try insulating the screen from the frame and clean the pressure contacts to see if it helps and update this with any new info.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi... Any update?
의 공유
댓글 달기
답변을 추가하세요
apriliamx5535 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 21
전체 시간: 2,362
