주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 1월에 출시된 Android 스마트폰입니다.
Mobile dead after wrong software update through flash tool
Hi Team,
Last night after doing the fast boot my device has stopped working. The screen is not getting on, I tried to plug the charger but there's no notification light. I tried to remove the battery for few minutes and still no hope. I also tried to load fastboot once again by pressing Vol UP + Power / Vol Down + Power / Vol Up + Down + Power still no joy. The next step I did is I remove the battery then insert my phone to my Laptop then I plugged back the battery, it wasn't detected.
even i check the following thread http://en.miui.com/thread-100553-1-1.htm...
which needs a bit of technical skill....but there is no luck on that as well
I have read many threads on forums about MI Flashing, the problem is I can't load my device neither in fastboot nor detect my phone.
Request your help on the same from chip level to repair the hardware as u t the one in market to fixit this issue.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Hi Edward
Thank u for the sol.. can u please suggest me how to resurrect it! , what n where i should do it, to make it work.
의
Sadly, I too lost a phone by inserting battery _while_ the phone was connected to charger/power. Cant fix.
의
댓글 달기
답변 2개
가장 유용한 답변
Do you mean you connected your phone without battery to laptop? And then while the phone was connected to laptop you inserted the battery? This would likely damage the main board due to surge in current.
Hope you can resurrect it! good luck and let us know if it works.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
read here http://en.miui.com/thread-126437-1-1.htm... or
here https://forum.xda-developers.com/redmi-2...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Siva 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 3,500
