주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia E7-00은 쿼티(QWERTY) 키보드가 내장된 비즈니스 중심의 스마트폰입니다. 2011년에 출시되었습니다.
How to change the USB port?
The USB port of my Nokia E7-00 has some bad contacts, depending on the angle of the USB wire with the phone, the phone is not charging or unable to transfer data to a plugged computer. I would like to change it but I don't know how and I'm a little bit affraid of trying without any advices.
I'll be very glad if someone could help me about this.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 1개
i finally had a go at analyzing this common failure ...
the root cause is that the plastic part within the usb port has/develops a tiny amount of wiggle room. this wiggle ultimately causes the outer pins to snap off right in the "knee" of the "L" shape which attaches to the PCB.
you can replace the socket (it costs "nothing"), or you can solder tiny bent wires to it - i did the latter, and it actually worked (dunno for how long).
you will need a hot air gun, a preheating plate (the motherboard sinks so much heat that there is no way hot air alone will be enough), flux, and a little fresh solder. if you do the wire magic, you'll also need equipment for soldering tiny parts - a short-shafted pointy soldering tip (J shape), a magnifier, and a sufficiently steady hand.
you can try closing the gaps in the broken leads while the socket is still soldered, but i don't think it will work, as the solder is unlikely to flow that deep, esp. with the enormous heat-sinking of the PCB.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sylvain 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 25
전체 시간: 925
