주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
10.0 메가픽셀, 10배 광학 줌, 이미지 안정화 시스템을 갖춘 내장 플래시 컴팩트 디지털 카메라입니다. 분해하려면 특정 장비가 필요합니다.
SD Card slot issue
The SD card will not stay in the slot. It no longer clicks into place. Has anyone ever repaired/replaced this part?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
JillEMoody , Check the video link below, you may have a small piece of debri inside the SD slot not allowing card pin to lock in card. If you do probe inside the slot be careful not to damage any of the readers contacts(very delicate). Good luck.
https://www.youtube.com/watch?v=ZgTK5g_j...
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
Thanks, but I think the spring is the issue. There's nothing in the port, and when I press the lever with a screwdriver it doesn't latch. Looks like I'm going to have fun taking the camera apart to see if I can find the broken spring.
Using my cell phone to light up and zoom in was useful.
의 공유
JillEMoody, The link/ guide partial tear down, below may help you take apart camera to access card port. Good luck with your device.
Canon PowerShot SX120 IS 스크린 교체
의 공유
What an amazing piece of advise, even I could understand it & I hope it helps me fix the camera, but I need the right sized screwdriver cos Philips screws were made to frustrate people like me.
의 공유
댓글 달기
It sounds as if you are putting the card in upside down. Try flipping it around. I hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
No, that's not the problem. You can't put the card in upside down in this camera, it doesn't fit that way. When I press down the card, it pops right back up. I've tried two cards, but neither will stay inserted.
Thanks, anyway.
의 공유
Hmmm... The spring that holds it in must have been knocked out of place. Try opening the camera up and taking look.
의 공유
Yes, that seems to be the issue. Thanks.
의 공유
Good. I'm glad I could be of help.
의 공유
댓글 달기
답변을 추가하세요
JillEMoody 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 21
전체 시간: 880
