주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia N8은 Symbian^3 운영 체제(OS)를 탑재한 최초의 기기이자 2010년 노키아의 플래그십 기기입니다.
Not Starting and Charging
I bought a nokia n8 2 weeks ago. Was using my phone sending text messages when it suddenly hung up and shut down. When I tried to power it on it won't start and tried to recharge it but the indicator light does not go on meaning it does'nt charge. Has anybody experience this with a nokia n8?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 2개
I got Same Problem Please Help Me
== Update ==
Whenever I Try To Start The Phone It Is Start I Can See Nokia Logo Also But Then Suddenly It Is Going To Switch Off
Please Help Me.
의 공유
try Hold "powerkey" about 8s/10s he gives you 3 vibes
if not turn on hold "powerkey" till phone awake
good luck
의 공유
댓글 달기
답변 6개
가장 유용한 답변
Same here. What i do for the moment is connecting to pc with usb cable- so that starting to charge via usb- would let u to start up the phone. simple and quick. but better refurbish the phone
이 답변이 도움이 되었나요?
점수 3
댓글 달기
If you encounter the thing that the Nokia N8 won't charge and worst, if the battery was drained and the N8 shutted down and won't charge or power on, try the following steps.
1. Connect the charger supplied with the N8 to other compatible Nokia phones, like E72 like I did.
2. Wait for the other device (E72) to start charging.
3. After it starts charging, remove the charger from it (E72).
4. Now, try to charge the N8 using the supplied charger that you used with the other device previously (E72).
5. Wait for the N8 to charge or start.
6. DONE!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
bro, thx, it worked!
(with the additional usb connected to a computer and then folowing your steps)
의 공유
and removing the sim
의 공유
댓글 달기
have yo held the power button when turning it on it does take a few seconds you can aslo try charging both through the power at the bottom and the mini usb at the side .
이 답변이 도움이 되었나요?
점수 0
댓글 달기
please all remove memory carn and sim card, then start your phone
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try to charge with a normal charger like samsungs charger. In the side of Nokia N8 there is a port for it. Worked for me :)
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
In the left side*^
의 공유
댓글 달기
Try replace the battery
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Victor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 79
전체 시간: 26,698
