주요 콘텐츠로 건너뛰기
The Gateway NV52 was released in 2008. It is similar to the MS2274 and NV5207u models.
16 질문 전체 보기
which monitor controller can I use for this laptop
My laptop stopped working, and I'm not interested in fixing it, but I want to use the monitor as a second display for my station, but I need a controller [if I understood correctly], can someone instruct me which controller to get?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@carrotsy that will depend on your display panel, not your computer. Disassemble your dispaly to the panel and take a look at the label on it. Most common panel for your model is a B156XW04 (there are different version recognized by the V.X number on that label. With that number do a search on either Alibaba.com or ebay.com for a "universal LCD controller board". You should find something like this. Again, always double check your LCD panel. To connect the kit is actually pretty easy. Check this guide for a bit of an idea what you are getting into.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I guess I was wrong again.
@pccheese not wrong you just have not build one yet. You are getting there, reps are looking good.
댓글 달기
귀하의 답변을 추가하세요
Salah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 159
