주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon D5200은 2410만 화소 DX-포맷 CMOS 이미지 센서를 탑재한 F-마운트 DSLR 카메라입니다. D5200은 최대 6000x4000 해상도를 지원하며 1080p 동영상 촬영이 가능합니다.
My camera just died!
I've fully charged my battery and when I try to open it, the green light flashes (as normal) but it doesn't open and when I see in the view finder, it indicates that it hasn't charged and the battery is empty even though I've just fully charged it.
P.S: I've tried another battery and it's the same
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
have you tried using another charger to charge the batteries and checking the voltage levels in the batteries to see if they are actually charged. It could well be that the mains charger is faulty and not charging the batteries properly.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I've tried it and it's the same
의 공유
my next advice would be to open the camera up and check the solder joints on the battery contact and motherboard side contacts, sorry there isn't a guide available on how to do this but the D5100 and D5300 are both similar cameras and open up pretty much the same way, so follow the guides on how to open those cameras as best you can.
의 공유
댓글 달기
If restoring camera to its default factory settings will fix this issue then its ok, otherwise visit Nikon D5200 Manual to proceed another solution.
To restoring Nikon D5200 to its factory settings, just hold down the [Menu button] button and the [Information button] button together, until the control panel turns off briefly while the camera resets itself to the factory default settings.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mustafa Hmood 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 14
전체 시간: 1,498
