주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.86GHz 또는 2.13GHz 프로세서, 128GB 또는 256GB 플래시 저장공간
Will not start up
My MacBook air stopped recently and I have been unable to start it I Have attempted to reset the smc to no avail. I have disconnected the battery and attempted to start it will the power connected again to no avail. Is this an i/o problem?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Remove the logic board and charging board, and clean any liquid damage using 95%+ isopropyl. If you are getting a charger light when a charger plugged in, it is likely the trackpad cable (check both ends, if burnt or liquid damaged, replace), trackpad PCB (check for burns or corrosion) or most likely the keyboard.
If there is no light on the charger, check the I/O cable for burnt pins. It could be the I/O cable, charging board, keyboard (shorting PP3V42_G3H to ground) or PP3V42_G3H is not being produced on the logic board, or is being shorted to ground.
Clean any liquid on the board first, but take a picture of where it is corroded before cleaning. If no liquid on the board, most likely will be the keyboard, if the charger is lighting up and the trackpad cable is fine.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
William Hawkins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 25
전체 시간: 729
