주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Atari 2600 또는 Atari Video Computer System(VCS)은 1977년 9월에 출시된 게임기입니다. 2600은 MOS Technology 6507 CPU를 실행하며 게임 저장용으로 ROM 카트리지를 사용합니다.
The screen seems dark
I just found my old 2600 in my garage, I cleaned it up and even fixed one of the controllers that was broken inside, so when I plug it in and turn it on the screen seems a lot darker than I remember it looking, what could cause this? everything else works fine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
@kazman72 how did you connect it to your TV and what TV are you using?
의 공유
I used the rca cable to the cable coax adapter method, I'm using a newer samsung hd tv.
의 공유
Did you check your RF switch on the back of the console? And the tip of the cord that goes into the console? Sometimes it gets dirty over time and doesn't get a good connection. I would suggest unplugging everything the get a qtip with rubbing alcohol and cleaning the connector on the console and the end of the cord. That works for me.
의 공유
댓글 달기
답변 1개
Try checking the screen settings on your television. On my LG I can set different lighting settings for different inputs, and some cause the screen to appear darker than others. Each input on your television will have different pictureh modes so setting it on one input will not automatically transfer it over to another.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jonathan Kazarian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 910
