주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
What Components are on the audio control cable?
Hi what components are on the audio control cable on the iPhone 6? And could the failure of these components cause the speaker to stop working?
Thanks to add a little more context I have an iPhone 6 that was water damaged and had many problems.
The following components have been replaced
Display Assembly which Includes
>Display
>Earpiece
> Front Facing camera
The Loudspeaker
The Lighting cable and headphone Jack.
The logic board was removed any given a bath in isopropyl alcohol and refitted.
Everything on the phone now works when the headphone are plugged in however the sound does not work when the headphones are unplugged.
I’m at a loss to work out what to try next.
Thanks
Alan
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
Volume button cable? Vibrate switch and pretty much that's all.
The top speaker (connected to front camera assembly) or bottom speaker (connected to charging port assembly)?
OK am about to Give up on this can not figure out what the problem is. Has anyone else got any ideas ?
Hmm... the fact that it has been water damaged makes it a little more complicated. Once a device comes in contact with liquid even after being cleaned with isopropyl alcohol it makes that phone incredibly unpredictable, also who's to say the components that have been replaced aren't faulty too. There are many variables to a water damaged phone so the fact that the phone is operating at all is considered a huge plus. I deal with liquid damage phones on a daily basis and the majority of them never come back to life, sorry to be the bearer of bad news but sometimes it's better to hear the hard truth. Good luck with it nevertheless.
Are the connectors on the logic board affected by the liquid damage at all like corrosion / burn marks?
Might want to try another charging port to rule it out being faulty.
댓글 달기
답변 2개
가장 유용한 답변
Hi there,
I think the audio cable you are referring to is the volume/mute ribbon cable, which has nothing to do with the main speaker not working.
The main speaker is connected to the charging port which in turn is then connected to the logic board, so the issue you have would need one of these replaced. On a side note some cases the phone could be stuck in 'headphone mode', which is where the device thinks that headphones are plugged in even though there are none present. Which again can be fixed with a charging port replacement because by chance the headphone jack and charging port share the same ribbon cable.
Hope this all helps!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
as the Audio is working The Audio Codec is good. as you have changed the dock flex then there is a board fault. to be specific the Audio Amplifier circuit. the Audio Amp is a simple repair if you have the tools and knowledge. failing that a tech can test and fix this easy
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks for your feedback Does the audio amplifier also affect the headphones and earpiece loudspeaker as both of those are working?
댓글 달기
귀하의 답변을 추가하세요
Alan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 68
