주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Furby는 햄스터와 올빼미를 닮은 인기 있는 전자 로봇 완구로, 1998년 연말 시즌 출시 이후 2000년까지 지속적인 판매고를 올리며 "필수 구매" 장난감으로 자리 잡았습니다. Furby는 1998년에 180만 대, 1999년에 1,400만 대가 판매되었으며, 초기 생산 3년 동안 총 4,000만 대 이상이 판매되었습니다.
Furby thinks his shaking.
Furby thinks it shake in the vertical position and therefore always turns into the evil.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Same problem with the 2012 furby model... It also wakes up by the minimal vibration he senses... I've searched online but I didn't found any comments about this problem...
I have the same problem since my 2012 furby decided to jump of my drawer when I wasn't looking
댓글 달기
답변 2개
가장 유용한 답변
How to get your Furby to change personality?
Default Personality. All Furbies start off like this. You can get this personality back by turning your Furby upside down, holding down the tongue, and holding the tail pulled for 2 seconds.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
This isn't related to the shaking problem at all. The furby tilt sensor is probably at fault here. It's broken/too sensitive and even when furby moves by itself(while dancing etc) he thinks he's being shaken. But it doesn't have to work like that. For example as soon as I reset it it goes into the grumpy personality because he thinks he's being shaken. It also wakes up by itself after he fall asleep because the movement he does while he's closing his eyes it makes him think he's being shaken.
댓글 달기
If your furby thinks it shaking while in the vertical position and switches its personality to evil/Feisty/ Viking mode. The furby tilt sensor is broken or too sensitive. For instance, if the furby dances, he may stop, since he thinks he's being shaken. I advise to take apart the furby to clean/replace his tilt sensor
This site might help even though it's for older Furby's:https://furbytech.tumblr.com/post/167541...
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Have you had any results fixing the issue in the 2012 furby? I'm having the same issue, and I found like 1-2 posts on reddit where people talked about not being able to fix it in their 2012 furbies / not being able to locate where the tilt sensor even is
@qhwohwfj I think I know which one is the sensor. It's the black "box" thing on the side of the Furby. On the pcb where there are others components. I actually thought it could be that when I disassembled the Furby a long time ago and I think there is a way to open it.
This site might help: https://furbytech.tumblr.com/post/174003...
or: https://learn.adafruit.com/furby-2012-te...
also: https://www.bot-thoughts.com/2013/03/fur...
This video is a full teardown so it may help as well: https://www.youtube.com/watch?v=DTp_gPqS...
There is sadly very limited information on Furby Tilt sensors out there.
댓글 달기
답변을 추가하세요
iambelkin13 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 20
전체 시간: 1,777
