주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
No GSM signal after teardown my iPhone 4! Help!
Getting low GSM signal outside of house and no GSM signal inside of home, wifi works, nothing bad, everythin works, only no GSM signal.
Checked many time, everthing connected.
Please help, o
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Heard someone talk about that"mounting screw" near by battery connetion, which one is it?
댓글 달기
답변 21개
가장 유용한 답변
Make sure both of the screws are tight on the bottom (be careful not to strip it) or try to switch it. If this doesn't work we can diagnose the problem further.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I recall four metal "fingers" on the speaker enclosure that is supposed to be related to signal reception. The fingers are supposed to be under the lip, not ontop of the board. I also know of that antenna connector close to the battery connector. Those are the only things I can think of that is antenna related.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
all of screws is up, and four metal fingers on the speaker enclosure is fine,
where is antenna connector?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Pretty easy to solve this,
There is a welder metal area on the top of the speakers enclosure, just separate it from the four metal fingers under it, this welder metal area is in circuit touch with one or more from these metal fingers which affecting the reception signal,
by smoothly separating them you'll retrieve your full signal back.
hope this helps
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
i Hasave the same problem and i tried everything that is listed in here and still no service
Update
@walter: thanks man, is there any specific ones that i have to clean
@daniel: yes, double check that it is connected
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The oils on your fingers have the potential to cause wireless interference issues. As stated throughout our iPhone 4 guides: "Before reassembly, be sure to clean all metal-to-metal contact points with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues." Hope this helps.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
i just finished cleaning every connection on it, its still ask no service :(
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Unfortunatelly i have the same problem :s
It just happened when i opened my iphone to try to fix my voice sending problem during a voicecall.
I've figured out the reason of my voice sending problem (it's about the sockets) but now i have the reception problem :(((
Are there any other connections of gsm antenna with other parts?
And the antenna connector near the battery socket..Does it effect Wi-Fi and Gsm both or just one of them?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
i had some problem, no gsm signal and very weak wifi, got strerng only when very close than router.
I think in buy one antenna parts but worry if problem is in logicalboard, whats do now?
Thanks
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
People. Check that you did not accidently break your antenna inductor on the logicboard.
seems to happen to many of us:
this is what i am talking about (pic on page) iPhone 4 INDUCTOR/COIL(BLUE)Near Wifi Antenna Plug in-- NO SIGNAL
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
After soldering the gap where the inductor thingy was before, my GSM signal came back to me :-)
댓글 달기
I has problem only with Wifi, the signal is very weak, powefull only when side of router and when lift room the signal lost. I buy one wifi antenna new and change, but not happens, whats can i do now? thanks
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
have you tried all the solutions listed above?
댓글 달기
Yes. All. updated to 4.3.3 and all tips alreadyu buy one antenna replace and changed and notthing im fell very very bad with this iphone now, im on Brazil and here has no official apple assistence, and this iphone is ATT so very sad. But i has some hope can found one way to fix that, afterall i payed about 900usd for that, not fair dont work wifi...
thanks in advance
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I has fix my gsm signal using this instruction
I use spesial glue for contacts, it can pass voltage. Usually such glue you can find in car shop and look for a glue which repair back window lines to warm it. Hope you understand me.
Thank you! It is my 1 post here=)
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Good job and yes, we can understand you well...:-)
댓글 달기
Why "No Service" after replacing LCD screen? is a post last night that i made. it will help you resolve the problem. its an easy fix
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Bridging the 2 solder points with a conductive trace pen worked for me. A precision solder bridge should also work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
replace it with a new blue iphone coil that will fix the problem
you can buy a new blue coil here for the repair
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
update video tutorial on how to change the blue coil on youtube.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If you have a repeater installer in town, they'll usually come do a full signal analysis and then just FIX IT. These guys cover people around San Antonio n stuff, but they answer questions pretty well. --> http://www.getmesignal.com/
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
IT Solution is a very important website for any kinds of IT based News and Solution. So, Always connected with this site and get more and more info with Solution which is make your IT life very easy. Also connected with our facebook fanpage “IT Solution” for more info......
Website: http://itsolutionusa.blogspot.com/
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is a common fault on iPhone. No connection to GSM net. The only sollution is backing up the phone via iTunes and perform (within iTunes) a factory restore. It's NOT a hardware problem something goes completely wrong with the software. I fixed this problem on a couple of iPhones 4 and 5 so I'm sure about it. Good luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Y L 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 13,030
