주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
듀얼 카메라를 탑재한 8인치 정전식 듀얼 코어 Zeki 태블릿입니다. 이 기기의 모델 번호는 TBQG884B입니다.
loading apps on sd card
After I reset tablet I was putting my apps back on SD card ,but I have 3 that will not load when I try to load them it says couldn't move app,.There is 4.2 GB of storage space on the card,but my tablet is running out of space.What can I do ,? HELP
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Problem solved thanks
의 공유
댓글 달기
답변 1개
선택된 해법
some apps will not go onto the sd card and some apps will only partially go on the sd card. this makes for some problems when you reset a phone. if the app wont go on the sd card then when you reset the phone you lose the app. if the app partially goes on the sd card when you reset the phone you lose a part of the app. there is really nothing you can do to solve this without rooting the device. about the only thing you can do is get a cleaner app like cleanmaster and constatnly clean your storage or figure out which apps you are not really losing and delete them. i hope that this helps and you are able to get all of your apps working again.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
jetherton1949 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 495
