주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Mobility에서 개발한 Android 스마트폰인 2세대 Moto X(moto X로 마케팅됨)입니다. 2014년 9월 5일에 출시되었으며, 2013년에 출시된 오리지널 Moto X의 후속 모델입니다. 모델 번호는 XT1097, XT1096, XT1095, XT1093입니다.
Overheating after screen replacement
So this will be the second Lens/LCD assembly we've ordered for this device due to the first replacement screen cutting off randomly and getting hot while turned on/charging/post testing device. So we ordered a new Lens/LCD assembly expecting a defective part on the first go. Round two, I've made sure to move all the protective tapes from the old screen to the new assembly and any other pieces of components that were in the old screen but not the new one. The phone is still heating up pretty seriously and cutting off from time to time after everything is put back together. Am I missing an important step that's causing a bad ground resulting in the overheating issue? At check-in, the receptionist made note of slight heat coming off of the device in its original condition, although the customer vehemently says overheating was never an issue. Anything would help. Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
refund customer and install their old screen. hold your ground about the phone being hot when brought in. stay calm even when customer gets angry, easier said then done but at this point, it's not your fault, unless you bent the board when taking it out originally and damaged something under the emi shielding. if you did not then you're trying to avoid a negative review and hope the customer still keeps faith in repair.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Steve B 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 467
