주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6s - Battery level drops suddenly without warning
My daughter and I both have an iPhone 6S that experiences sudden drops in battery level causing the phones to shut down. This happens from 35%-50% battery levels. Plugging the phone into a power source re-starts the phone with the battery level again indicating 35%-50%. This is an identified issue and Apple has a repair program if your serial number falls within a certain range. Both of our phones qualify so the reason I've posted this question is to help others who might not be aware of the program. This program is in effect for 3 years after purchase and the fix is no cost to the consumer.
https://www.apple.com/uk/support/iphone6...
I post this here only because the program is not widely advertised and others may benefit from this information. I've been a user of Apple gear since 1995 and am a lifelong fixer.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -2
댓글 2개
I forgot to add that this repair is at no cost to the consumer and takes about an hour if you take your phone to an Apple Store. You could alternatively send the phone to Apple but the turnaround is 7 days.
I would like to add that Apple often decides you have a new problem, and wants you to pay for it. Or more likely they want you to buy a new phone. Also, it doesn't take an hour. It takes twenty minutes to see a person, then likely another 3-4 hours to have something taken care of
댓글 달기
답변 2개
선택된 답변
While goin to Apple can sometimes be beneficial. I've found more often than not, that's not the case. I would advise checking how much it would cost, and if they would deem you have more problems, and basically want more money from you. This is the route I would go
Parts
iPhone 6s Battery
Labor
iPhone 6s 배터리 교체
Also, it's important to know, that after removing the display and battery, it's very important to discharge the battery. Holding down the power button for four seconds, as the newer iPhones hold a charge, and can hurt parts, when connected back to the phone
iPhone 6s Battery 이미지
상품
iPhone 6s Battery
$29.99
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
This answer is not relevant to the original post.
It has everything to do with the op. If you like apple and their cold cryptic answers that suck up all your dollars. More power to ya. However around here, we're more about finding solutions that help and save the community money. Also, we all knew about this. But thanks for bringing it to our attention anyways
댓글 달기
As said and to piggy-back on his response above, I would check on replacing your battery.
It would be advised to let a trusted professional do the replacement so that the adhesives holding your screen assembly down could be replaced after, so that you would maintain the water resistance on your 6s.
해당 답변은 도움이 되었습니까?
점수 0
댓글 12개:
The iPhone 6S is not officially water resistant.
Water resistant, not water-proof sir.
You as a tech should know the difference. Adhesives are on to maintain a level of water resistance for the device.
I know the difference...Apple does not state anywhere that the iPhone 6S is water resistant. It has extra adhesives, yes, but Apple does not claim any water resistance. That is for the iPhone 7 only.
Check for yourself before telling others they are wrong.
Official Apple Site: https://www.apple.com/iphone-7/specs/
Splash, Water, and Dust Resistant: Rated IP67 under IEC standard 60529
Official Apple Site: http://www.apple.com/iphone-6s/specs/
No such spec or mention anywhere.
Like I said...The iPhone 6S is not officially water resistant.
The point of this post was to inform that the device should be returned back to factory as close as possible, including reapplying adhesives on the perimeter to maintain a level of "water resistance". Your extra chime in that has nothing to do with the initial issue of the post and speaks volumes to the level of repair you must do.
댓글 7개 더보기
댓글 달기
귀하의 답변을 추가하세요
davidswanson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 116
