주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple 제품과 호환되도록 설계된 피코 프로젝터입니다.
no projection or light
Continuation has the purchase of a cinemin swivel, I have a problem:
When I switch on the pico connected to an ipod, an image is projected with the cinemin logo; but two seconds after, nothing more no projection or light which goes out of the device.
By looking the lens I has fault sees a small light at the bottom of the device
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Any fix for this problem with the swivel?
의
nyl777, it would work so much better for you if you ask your own question and give as much detail as possible if you are expecting any help with your device. Your two questions on ifixit actually show up as answer to older questions. Click on the link on the right hand side of this page, where it says" Ask a question" Give it a try, it is not difficult and you may get some help for your problem. Good Luck.
의
댓글 달기
답변 4개
선택된 해법
Sounds Like a the bulb has burnt out. Hopefully its not to expensive.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
How to be safe that It is the bulb, because the device does not have was used
의
He reacts in the same way when no device is above connected
의
댓글 달기
Are you using it with an iPhone, iPod, or iPad? Because if you are, you need to use the little adapter. It should plug into the charger port of the iProduct, not the headphone port, and then the 3.5mm plugs right into that. I had this same problem, until I noticed the adapter lol
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It may be the cord or the adapter. Sometimes, I have to plug my DVD player white into the yellow, and the yellow into the white in order to get the picture. It's like a crossed wire or something.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이미지
Does anybody know where I can find the blue cord that connects the cinemon swivel 8410 projector component with the battery component?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
specie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 3,236
