주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi가 탑재된 3세대 Apple iPad의 수리 안내서, 분해 정보, 문제해결 정보를 제공합니다. 16, 32, 64 GB 저장 용량으로 제공됩니다. 2012년 3월에 출시되었습니다. 모델 번호 A1426으로 식별됩니다. 수리 시 열을 가하고 조심스럽게 들어내는 작업이 필요합니다.
Bottom of screen not working
I've changed the screen on my iPad 3 and put a tiny crack in the new one when doing so. If you take the screen out and flip it over, the crack runs through the tiny silver coloured lines running around the edge of the screen just above the home button. Is this why the bottom of my screen will not work now? Or do they have nothing to do with it? I've tried to clean out the terminals where the tape connects in but that hasn't done anything.
It's literally the bottom half inch that doesn't work.
All help is much appreciated
Thanks
Dru
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
If the crack is on the digitizer layer and not the black glass then yes you will need to replace the digitizer again.
의
댓글 달기
답변 1개
선택된 해법
Hi,
Yes, this damage will cause the touch to stop working, or if you have damaged the cable by crushing it etc.
Get a replacement digitiser, and make sure none of the corners or side walls are dented, otherwise your new digitiser will always crack, due to the fact it doesn't fit correctly. :-)
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
That's what it is!! The case is dented from where it has been dropped. I think I need to bend it out a little more in order for the screen to fit correctly. That must have caused the crack when I was replacing it.
Thanks a lot, really helpful!!
의
Not a problem! Glad I could help :-)
의
댓글 달기
답변을 추가하세요
Dru 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 73,360
