주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 M4753 / 233, 250, 266, 292 또는 300 MHz G3 프로세서
System Recovery PowerBook g3 Series
Hi!
I have PowerBook g3 Series. m4753
Very old version, I know. But I likke the classic.
When I turn it on, it uploads. But after I see white screen with a diskette and a question mark inside. After 1-2 min, it turnes off. Also when the question mark is on my screen, i hear little scratches. Not so loud, right side but not CD.
If you could help me please, thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Not good ;-{
Your hard drive has failed! The scratching noise is likely the head assembly rubbing on the disk.
You'll need to find a replacement drive which will be hard as the drive is an older PATA unit (IDE). Once you get the drive out you should be able to search for a replacement using the make and model info on the drive for an exact replacement. Finding one new will not be easy, more likely to find a used one.
Here's the IFIXIT guide you'll need to follow to replace it: PowerBook G3 Wallstreet Hard Drive Replacement. In addition, you'll need to find a copy of the older Mac OS-9 on a CD to prep up the replacement drive if you still have the grey disk that came with your system you'll be all set otherwise you'll need to hunt down a retail version of the software on eBay.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Given its age it's a nice show piece if it's not worn (collectible). If you are planning on using it I would recommend you put your pennies into a newer model (new or used)
의 공유
댓글 달기
답변을 추가하세요
YanC 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 569
