주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One Mini 2는 2014년 5월 유럽, 중동, 아시아에서 출시되었습니다. 모델 번호 M8MINx인 HTC One Mini 2는 단일 후면 카메라와 16 GB 저장 공간을 특징으로 합니다. HTC One Mini 2는 HTC One M8과 매우 비슷하지만 크기가 더 작고 가격은 더 저렴합니다.
Motherboard replacing from EE to O2
As in topic.
I changed motherboard in my HTC One Mini 2... and rear camera stop to working. Front camera works fine. Originally motherboard and phone was EE, now motherboard is from O2. Because motherboard was O2 I must unlock phone, I did it.
After unlocking rear camera sometimes was working, and on second day after motherboard replacing, completly stops to work.
After motherboard changing everything works fine except rear camera...
Any suggestions...?
Update (02/23/2017)
Hello,
I fixed problem with silver colored tapes. This is not a solution...
I think back cover cause problems with camera. Nothing else, just back cover. Camera works without back cover! I try find solution.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Hello,
I fixed the problem. Ribbon cable connector located at the bottom of the upper circuit board caused the problem. I changed it and now everything works fine. Step 13 "Battery" at HTC One Mini 2 배터리 교체 middle picture at that step.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check the camera has a good connection to the motherboard or maybe buy a new camera and see if that fixes it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Thanx for your reply. I force stopped camera and then I cleared data and cache and for a couple of times it starts to work... but just for a couple of times...
About your suggestion: camera has a good connection to the printed circuit board (PCB) above motherboard and once I replaced camera, but without success, does not work...
But... when I have been changing motherboard I did not or not seal properly three woven, silver colored tapes to the motherboard and one silver tape by mistake I cutted...
Do you think, there an important woven, silver colored tapes...
Thanx for your reply!!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Piotr 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 20
전체 시간: 344
