주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Verizon Wireless용 RIM BlackBerry Curve 8330은 통합 Bluetooth 및 GPS를 제공합니다.
Trackball will not scroll vertically only laterally.
Can I purchase the trackball assembly and replace it myself or is the phone junk at this point?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Surprisingly you can pop the trackball assembly off to replace! Here is the part you'll need: Blackberry Trackball Replacement for Blackberry Curve 8300 & Pearl 8100 Series - White and here is the guide to replace it: Blackberry Curve 8330 Track Ball Replacement.
As long as the hall sensors are working you should be fine.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
DENNIS,I have taken the trackball out of it's square housing. YOU MUST BE VERY GENTLE THROUGH-OUT THIS COMPLETE PROCESS. You can get hold of myself at mcmurdojohnston@gmail.com. Taking a medium sized safety pin,and drawing it on your leather belt ,making sure there is no bent tip on the pin point ,as this can damage the ball,or the "pick-ups" inside the housing.Gentley insert the pin between the ball and the soft yellowish circular housing. This must go no deeper than the depth of what you yourself can see on the unit. I use a 40-60 watt light,and hold the complete unit close to bulb. when your fingers get warm, that is enough warmth to make the ring ,Malible enough to pry it back away from the ball. You will not need to go much past the "half-way" mark of the circle.You will see the trackball becoming quite loose,at this point,you may put the pin a little deeper,and VERY GENTLEY LIFT ON YHE BALL. Now you will find quite a bit of lint etc. inside the cradle which holds the ball. I use part of a bamboo chop stick sanded to a point, to clean out,all 4 quadrents,of contacts and in corners. Try to blow into the cradle areas through the "corners" underneath,or outside of the unit,as much less chance of jamming a piece of lint deep inside of the cradle. when finnished, return trackball to it's housing ,and use the bamboo to gently work the soft ring back snug around the ball. "BOB'S YOUR UNCLE"
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dennis Meyer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 400
