How to remove dead batteries from flashlights?
Does anyone know how to get dead batteries out of flashlights when the batteries have swollen up and wont slide out on their own?
좋은 질문입니까?
좋은 질문입니까?
Brian R , Wear gloves and eye protection. If normal type battery, drill a small pilot hole in battery, use an old cork screw or coarse lag screw threaded into battery(approx. 1/2 way or a little more). If really stuck and corroded you may have to heat the flashlight casing up with a hair dryer/heat gun to aid in removal of batteries. Grasp the cork screw/screw and pull battery out. repeat for second battery if needed. Dispose of old battery in appropriate manner. Video links below may help. Good luck.
이 답변이 도움이 되었나요?
I forgot to mention this is an AA Maglite. Thank you for the helpful responses!
I had a battery seize at the very top of my 4 D-cell Maglite. I soaked it in baking soda and water to neutralize the acid. Then used vinegar and baking soda to help break the corrosion sealing the battery to the maglite body. Rinsed thoroughly then used canola oil to get in between the battery and the body. All these steps were done over 48 hours. I then placed the oiled assembly in the freezer for 48 hours. After 48 hours I placed the maglite in the oven for 5 minutes to heat and expand the aluminum body. After 5 minutes of gentle taps on piece of 2x4 on the concrete floor, the battery slid out with relative ease. Note, you should disassemble the flashlight before starting any of the above steps. I drew the lens, the bottom lid, take out the bulb, gently pry off the rubber button then use a 5/64” Allen Key in the button. Wash all parts to remove oil and dry. Clean any residual corrosion from inside the maglite body with a tube brush wash, rinse and dry. Reassemble and viola, you saved your flashlight.
It’s not battery acid. These are alkaline batteries I assume (since they leak <snark>). So you are seeing alkaline salts. The vinegar will neutralize it. Don’t mix vinegar and baking soda. There are million suggestions to do this, but it’s just a circus trick. It foams, but that’s the acid base reaction, it’s not like soap. You just get water and a salt — completely useless.
The real answer is to quit using alkaline batteries, they are guaranteed to leak. Use NiMH. Superior in almost every way, including cost.
Fred's correct that NiMH will perform better physically (and electrically -- the discharge curve is flatter than alkaline) but they must be treated with care in maintaining their charge if you want them to have a long service life. Any trickle-discharge will kill NiMH if they're allowed to run down, but thankfully most flashlights that use primary cells have simple on/off switches that remove the discharge path. Self-discharge can be a secondary threat to service lifetime so you should regularly maintain their charge (on maybe a 3 month service cycle).
If this one has both a removable light and removable bottom take both off. You should then be able to get a screwdriver in and help push the batteries out.
이 답변이 도움이 되었나요?
For removing a stuck (AA) battery - from my camera - this worked like a charm and was least intrusive.
이 답변이 도움이 되었나요?
Needed to remove 3 stuck AAA batteries from a laser level. All metal body and access only to one end (where the battery cap goes). Battery #1 came out after a lot of prying. Battery #2 was stuck. I tried a long narrow pick, WD-40, baking soda solution. Nothing.
I finally found a long decking screw and drill bit long enough and drilled a hole into the top of battery #2. Was able to drive the screw in far enough that I could pull the stuck battery out. #3 was also stuck, but I was able to loosen it with a long, narrow flat head screwdriver. Ugghh…. not pretty, but it worked.
이 답변이 도움이 되었나요?
I had a small mag flashlight that used a single AA battery; so I did the drill trick and screwed a 2" tapping screw about half-way down the center of the battery. Then with the head sticking out of the top; I used a small pair of vise-grips and pulled it right out with no chemicals, fluids, etc.
이 답변이 도움이 되었나요?
지난 24시간: 6
지난 7일: 86
지난 30일: 401
전체 시간: 87,604
댓글 2개
Use rubbing alcohol just pour in flashlight hole use a flat head small screw driver like the kind you get with a eye glass repair kit. Get in there and go around all the edges if that fails drop some baking soda in it. Go around edges again. When it comes out .. rinse Out with alcohol let dry..
Kathleen Gardea 의
Okay so it’s October 2023 and my old 5cell maglite has the end battery (near the spring) solid and has leaked ( we think I fitted these batteries about 25 years ago ish). I have drilled a hole in the battery , stood the torch up on its lens endand am now soaking in WD40 overnight.. hopefully can try the vinegar trick tomorrow .. fingers crossed
phil Bear savory 의
