주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cinema HD는 투명한 케이스에 담긴 "레터박스" 형태의 LCD 디스플레이입니다. 2002년 3월에 출시되었습니다.
Clean transparent panels on the inside?
I have two of these monitors - the acrylic non aluminum. Both of them have a lot of dust (one even a dead spider) on the inside of the transparent plastic.
What is the easiest way to clean them on the inside? I know the back panel is fairly easy to remove but what about the front panel?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Is there a way to detach the transparent acrylic front from the white base to remove the dust underneath?
댓글 달기
답변 1개
선택된 해법
This one’s actually pretty easy.
  • Unplug the monitor.
  • Lie the panel down flat on a soft protective surface
  • There are 3 screws on the underside of the hinge/leg assembly. Remove those and the leg and hinge cover come off. Set aside.
  • Remove the three screws located on each side. There will be 12 in total to remove from this panel. Afterward, the back panel can be lifted off.
  • CAUTION: the front of the screen retains the front of the “easel” legs as part of the front facade. Take care to not bend/snap or otherwise flex these so they don’t break off.
  • Take care to set the removed clear panel so it does not get scratched. This can be wiped out with isopropanol wipes, as can the front bottom of the legs that are still attached to the monitor.
  • Reassembly is in the reverse. Ensure that the leg bottoms in front are seated properly into the rear case before securing screws.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 17
전체 시간: 1,346
